[Gdal-dev] Method to get a google image by url?
Garrett Potts
potts at cfl.rr.com
Thu Nov 15 12:38:25 EST 2007
Hello:
I think it is illegal based on their license terms to even download
and/or use their image server in your own applications. They have
license agreements with their image providers that the data will only
be used through their tools?? Can't remember, I get caught up in
their legalities.
Take care
Garrett
On Nov 15, 2007, at 12:21 PM, Brian Hamlin wrote:
> I am not pointing any fingers, but...
> I was speaking with one of the Google developer relations people
> yesterday. There is a problem in the field with downloading a lot
> of Google's tiles and making things with them.. (I saw two
> examples) There is a denial of service that kicks in at some point.
> Google is aware of some of these cases, and is increasing scrutiny
> where appropriate.....
> -Brian
> On Nov 15, 2007, at 7:52 AM, Joaquim Luis wrote:
>> Thanks Garrett
>> Some search helped me to find that (in my case of course) this
>> solves the problem (windows)
>> set http_proxy=proxy1.si.ualg.pt:8080
>> Joaquim Luis
>>> I think for any http requests GDAL uses libcurl. There is a
>>> global environment variable (I think) that you can set outside
>>> your software for libcurl to go through a proxy. Let me dig
>>> around real quick
>>> Take care
>>> Garrett
>>> On Nov 15, 2007, at 9:48 AM, Joaquim Luis wrote:
>>>> Frank Warmerdam wrote:
>>>>> If you have libcurl support included in your GDAL build you can
>>>>> just do:
>>>>> gdalinfo 'http://kh.google.com/kh?v=99&n=404&t=tqssrrqstt'
>>>>> That is, GDAL has a special "HTTP" driver that will fetch from
>>>>> an url
>>>>> and access the data from a memory buffer.
>>>> Frank,
>>>> Thanks that's cool, but before I dig out how to get the image in
>>>> memory let me bug you with one further question.
>>>> How do we declare a proxy?
>>>> (you command worked at home but not here at the University -
>>>> firewalls)
>>>> Thanks
>>>> Joaquim
>>>> _______________________________________________
>>>> Gdal-dev mailing list
>>>> Gdal-dev at lists.maptools.org
>>>> http://lists.maptools.org/mailman/listinfo/gdal-dev
