[Gdal-dev] Export Aux File from GDAL dataset?
Michael S. Rosen
mrosen at lizardtech.com
Tue Nov 20 17:39:14 EST 2007
Lennox,
If you've got a GDAL dataset of one sort, you should be convert it to an
HFADataset without undue difficulty. The HFADataset will write out the
.aux file you need.
Set up your HFADataset something rather like this, I think:
char **papszOptions = NULL;
papszOptions = CSLSetNameValue(papszOptions, "AUX", "YES"); //
create aux file only (no raster data)
int nXSize = pImage->getWidth();
int nYSize = pImage->getHeight();
int nBands = pImage->getNumBands();
GDALDataType eType = GDT_Unknown ;
switch (pImage->getDataType())
case LTI_DATATYPE_UINT8: eType = GDT_Byte; break;
case LTI_DATATYPE_SINT8: eType = GDT_Byte; break;
GDALDataset *poDstDS;
poDstDS = poDriver->Create(fsOutput.utf8(), nXSize, nYSize,
nBands, eType,
papszOptions);
// Add the metadata we choose to support
const LTIGeoCoord &geo = pImage->getGeoCoord();
double xUL, yUL, xRes, yRes, xRot, yRot;
geo.get(xUL, yUL, xRes, yRes, xRot, yRot);
double adfGeoTransform[6];
adfGeoTransform[0] = xUL - 0.5 * xRes; // Upper left corner of
upper left pixel
adfGeoTransform[1] = xRes;
adfGeoTransform[2] = xRot;
adfGeoTransform[3] = yUL - 0.5 * yRes; // Bottom right corner of
bottom right pixel
adfGeoTransform[4] = yRot;
adfGeoTransform[5] = yRes;
CPLErr err = poDstDS->SetGeoTransform(adfGeoTransform);
const char *pWkt = geo.getWKT();
OGRSpatialReference oSRS( pWkt );
oSRS.exportToWkt(pWkt);
err = poDstDS->SetProjection(pWkt);
// This destruction causes GDAL's driver to flush to disk
if (poDstDS != NULL)
delete poDstDS;
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Lennox Antoine
Sent: Tuesday, November 20, 2007 11:56 AM
To: gdal
Subject: [Gdal-dev] Export Aux File from GDAL dataset?
Hi All,
A colleague of mines has 1500+ MrSID files with no coordinate system
assigned. They are trying to read this using ERDAS IMAGINE.
I can easily assign the coordinate system in GDAL, however, there is no
way (that I know of) to get IMAGINE to recognize the coordinate system
since it stores auxiliary information in aux files.
I am wondering if there is a way to export the aux files from the GDAL
dataset, so that when IMAGINE reads it back, it gets the correct
coordinate system?
-Lennox
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071120/90b7d729/attachment.bin
