[Gdal-dev] Method to get a google image by url?
Zhonghai Wang zhonghaiw at gmail.com
Wed Nov 21 10:02:06 EST 2007
Hi Frank,
I've set the CONFIG in mapfile, but it still doesn't work, mapserver still
cannot access the raster images specified in the tile index file with http
links. The error message is something like:
msDrawRaster(): Unable to access file. (http://....../m_128_52_40000.gif);
I should mention that I've compiled MapServer myself under VS2005 with the
MapServer 5.0 source code. MapScript is compiled with libcurl support.
Do you have any idea about what is going wrong?
Best Regards
Zhonghai
On Nov 15, 2007 3:34 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Zhonghai Wang wrote:
> > Hi there,
> > that's a very good point for me. Several days ago I've tried to access
> > tiled indexed raster images via a http link in MapServer, but I did
> > NOT get it run, is there any KEYWORD in MapServer to switch this
> > functionality on? like the GDAL_SKIP DODS command?
> > Best Regards
> > Zhonghai
> Zhonghai,
> You can set GDAL/OGR configuration variables in MapServer using the CONFIG
> keyword in MAP section.
>   CONFIG "GDAL_SKIP" "DODS"
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071121/74c5a779/attachment.html
