[Gdal-dev] recent compile on cygwin?
Mateusz Loskot
mateusz at loskot.net
Wed Nov 21 23:21:59 EST 2007
Matt Wilkie wrote:
>> Perhaps you have it installed in different location than:
>> /usr with /usr/include/xercesc
>> or
>> /usr/local with /usr/local/include/xercesc
> xerces files are located in /usr/include/xercesc
This location is correct, so Xerces prefix is /usr.
> and a single lib file:
> /usr/lib/libxerces-c25.dll.a. Full listing is attached.
I have no idea how cygwin works, but GDAL building configuration
expects to link against -lxerces-c. IOW, libxerces-c.so file is used.
Recently, I significantly improved Xerces detection for Unix
http://trac.osgeo.org/gdal/ticket/1988
(see last big comment)
and perhaps now it will work for you, but I'm still doing a palmistry.
> There is a note in /usr/share/doc/Cygwin/xerces-c-2.5.0.README which
> says "Also, since the library exposes C++ classes, then applications
> using the library should be built with the same version compiler,
> otherwise there will be link errors." Might this be what is happening?
The only thing I can say is "perhaps". Haven't used cygwin, so no
experience here.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
