[Gdal-dev] recent compile on cygwin?
Matt Wilkie
matt.wilkie at gov.yk.ca
Tue Nov 27 15:08:50 EST 2007
Hi Mateusz,
I tried again today against svn revision 13119 and configure still
doesn't find libxercesc. Or more precisely, the xercesc headers are
found but the library is not. Config.log attached.
thank you for efforts looking into a build environment you personally
don't have access to. I guess we'll have to wait for a developer with
cygwin experience to get interested.
take care,
-matt
Mateusz Loskot wrote:
> Matt Wilkie wrote:
>>> Perhaps you have it installed in different location than:
>>> /usr with /usr/include/xercesc
>>> or
>>> /usr/local with /usr/local/include/xercesc
>> xerces files are located in /usr/include/xercesc
> This location is correct, so Xerces prefix is /usr.
>> and a single lib file:
>> /usr/lib/libxerces-c25.dll.a. Full listing is attached.
> I have no idea how cygwin works, but GDAL building configuration
> expects to link against -lxerces-c. IOW, libxerces-c.so file is used.
> Recently, I significantly improved Xerces detection for Unix
> http://trac.osgeo.org/gdal/ticket/1988
> (see last big comment)
> and perhaps now it will work for you, but I'm still doing a palmistry.
>> There is a note in /usr/share/doc/Cygwin/xerces-c-2.5.0.README which
>> says "Also, since the library exposes C++ classes, then applications
>> using the library should be built with the same version compiler,
>> otherwise there will be link errors." Might this be what is happening?
> The only thing I can say is "perhaps". Haven't used cygwin, so no
> experience here.
> Cheers
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071127/93730444/config.log.gz
