[gdal-dev] GDAL/OGR 1.4.4 Release Candidate 1 - NOT SO GOOD news
Howard Butler
hobu.inc at gmail.com
Fri Nov 23 19:39:09 EST 2007
I don't know that you are being ignored, and what was submitted before
the release candidate was not a patch, but an entire source file.
Additionally, Frank has targeted this work until the 1.5 release, and
it is not for the 1.4 branch. The 1.5 beta is on the horizon shortly,
but these changes will not be backported to the 1.4 branch unless we
have a 1.4.5 branch and Frank determines that they are safe to backport.
Howard -- 1.4.4 Release Manager
On Nov 23, 2007, at 6:09 PM, Joaquim Luis wrote:
> The netCDF driver is still broken.
> I have repeatedly reported that netCDF COARDS compliant grids
> created by GMT have their header reported incorrectly.
> fast example
> grdmath -R-10/10/-10/10 -I1 = lixo.grd
> C:\>gdalinfo NETCDF:"lixo.grd":z
> Driver: netCDF/Network Common Data Format
> Size is 21, 21
> Coordinate System is `'
> Origin = (-10.500000000000000,-10.500000000000000)
> Pixel Size = (1.000000000000000,1.000000000000000)
> Metadata:
> NC_GLOBAL#Conventions=COARDS, CF-1.0
> NC_GLOBAL#title=lixo.grd
> NC_GLOBAL#history=grdmath -R-10/10/-10/10 -I1 = lixo.grd
> NC_GLOBAL#GMT_version=GMT4.2
> NC_GLOBAL#node_offset=0
> z#long_name=z
> z#_FillValue=1.#QNAN0e+000
> z#actual_range=00
> z#coordinates=x y
> x#long_name=x
> x#actual_range=-1010
> y#long_name=y
> y#actual_range=-1010
> Corner Coordinates:
> Upper Left ( -10.5000000, -10.5000000) <=== WRONG
> Lower Left ( -10.5000000, 10.5000000)
> Upper Right ( 10.5000000, -10.5000000)
> Lower Right ( 10.5000000, 10.5000000)
> Center ( 0.0000000, 0.0000000)
> I have also submitted a patch that corrects this problem
> http://trac.osgeo.org/gdal/ticket/1926
> why is it being ignored?
> Joaquim Luis
