[gdal-dev] 3D maps
Malm Paul
paul.malm at saabgroup.com
Tue Nov 27 02:05:37 EST 2007
Hi!
I have a geometry set of triangles (e.g land area), including
elevations.
To be able to view e.g roads ontop those triangles I must insert points
in the road polylines with the correct elevation in each intersection
(roadline - triangle border). Att the same time I would like to insert
the correct elevation of the original points of the road-polyline. is
there a command that could do this for me?
Kind regards,
Paul
