[gdal-dev] split multipolygons?
    Milo van der Linden
    milovanderlinden at gmail.com
    Mon Nov 26 13:02:52 EST 2007
Thank you Frank,
I will test the wher clause, come up with the right quoting and post my
final result to the list.
Kind regards!
Milo van der Linden
Frank Warmerdam schreef:
> Milo van der Linden wrote:
>> Hello list,
>> I have a table in mapinfo format that contains different geometry
>> types. some are errors and when I filter out the errors, multipolygon
>> and polygon remain.
>> I try to use ogr2ogr  with -nlt to only get polygons. This doesn't
>> work the way I want it. When I open the resulting table in OpenJUMP,
>> there are still multipolygons in my table which prevent me from
>> saving changes I make with OpenJump.
> Milo,
> The -nlt switch sets the type of a layer, but doesn't - in itself -
> alter what geometries get written to the layer.
>> What I would like to know is if it is possible to split multipolygons
>> to polygons with regards to maintaining the attributes. Can this be
>> done?   kind regards,
> With GDAL/OGR 1.4+ you should be able to do something like:
>   ogr2ogr out.shp in.shp -where "OGR_GEOMETRY = 'POLYGON'" in
> I'm not sure if I have the quoting right.
> Basically, OGR_GEOMETRY is a special field that will contain
> the OGC WKT name for the geometry per:
>   http://trac.osgeo.org/gdal/wiki/rfc6_sqlgeom
> It can be used in attribute filters.
> Best regards,
3DSite - Milo van der Linden - CTO
A. Joachimi kade 3 F, 4461 BG  Goes
(Zeeland, Nederland)
milo at 3dsite.nl <mailto:milo at 3dsite.nl>
http://www.3dsite.nl
De informatie verzonden met dit e-mail bericht is uitsluitend bestemd
voor de geadresseerde(n). Gebruik van deze informatie door andere dan de
geadresseerde(n) is verboden. Openbaarmaking, vermenigvuldiging,
verspreiding en/of verstrekking van deze informatie aan derde is niet
toegestaan. Kopiëren en/of misbruiken van ingesloten afbeeldingen en/of
bestanden is wettelijke verboden en strafbaar. 3DSite staat niet in voor
de juiste en volledige overbrenging van de inhoud van een verzonden
e-mail, noch voor tijdig ontvangst daarvan. Op al onze leveringen,
aanbiedingen en verkopen zijn van toepassing onze Algemene Voorwaarden,
zoals gedeponeerd bij de K.v.K. te Middelburg. 3DSite
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071126/77e5553e/attachment.html
