[Gdal-dev] BSB format and legal issues
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 5 19:43:19 EDT 2007
Christopher Barker wrote:
> The BSB file format is the sole property of Maptech, Inc. and as such is
> protected by U.S. and International foreign copyright and patent laws.
> "BSB File Format” is a trademark of Maptech, Inc.
> I don't know what that means exactly.
Christopher,
I believe BSB read support is *enabled* by default, but can be turned
off fairly easily. But write support is #ifdef'ed out or something since
it is more questionable whether we can write BSB files without infringing
a BSB compression patent.
I don't recognise a file format as something that can be copyrighted.
Code can be copyrighted. A document describing a format can be copyrighted.
But I don't believe the format itself can. So Maptech is (IMHO) left
asserting trademark on "BSB File Format", a patent that covers the compression
scheme used to write BSBs (but does not restrict reading), and possibly they
have a DMCA case protecting ecrypted BSB files.
That leaves me reading unencrypted BSB files when I can reverse engineer
the format adequately without signing any "paper" with Maptech, or using
any of their private documents.
Note, I am not a lawyer, and the above should not be construed as qualified
legal advice. I'm giving my uneducated take on the documents and claims I've
seen.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
