[Gdal-dev] Normalizing color maps..
Mon Oct 8 10:59:51 EDT 2007
Burak BAYER wrote:
> Hi,
> Is it possible to normalize or rebuild color map of different GeoTiff
> files.. I have map data of Turkiye and when I merge them with
> gdal_merge.py, color data of whole map become corrupted because of each
> tile has different color table.. So how can I merge them with correct
> color entries..
Burak,
To mosaic colormapped images with different colormaps, you need to first
convert the images to 24bit RGB format (with pct2rgb.py).
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
