[Gdal-dev] import _gdal issue
Christopher Schmidt
crschmidt at metacarta.com
Tue Oct 9 18:33:43 EDT 2007
On Wed, Oct 10, 2007 at 10:22:25AM +1300, Simon Hope wrote:
> >>> import _gdal
> And don't get any errors and have access to the members on that module.
Pythonwin is probably using a different PYTHONPATH than apache is.
Somewhere in that path _gdal is probably included. Others can probably
comment more directly, but I would do something like:
import _gdal
print _gdal
Which should give output like <module 'gdal' from
'C:\SomethingOrOther\gdal.dll'> or something similar.
Once you've done that, you should be able to add the following to the
FeatureServer cgi:
sys.path.append("C:\SomethingOrOther")
after the 'import sys' and before the 'import FeatureServer' lines.
Regards,
Christopher Schmidt
MetaCarta
