[Gdal-dev] import _gdal issue
Christopher Barker
Chris.Barker at noaa.gov
Tue Oct 9 19:35:59 EDT 2007
Christopher Schmidt wrote:
> On Wed, Oct 10, 2007 at 10:22:25AM +1300, Simon Hope wrote:
>>>>> import _gdal
>> And don't get any errors and have access to the members on that module.
> Pythonwin is probably using a different PYTHONPATH than apache is.
> Somewhere in that path _gdal is probably included. Others can probably
> comment more directly, but I would do something like:
> import _gdal
> print _gdal
> Which should give output like <module 'gdal' from
> 'C:\SomethingOrOther\gdal.dll'> or something similar.
> Once you've done that, you should be able to add the following to the
> FeatureServer cgi:
> sys.path.append("C:\SomethingOrOther")
It's worth a try, but something is odd. From that traceback:
File "C:\Program Files\Apache Software
Foundation\Apache2.2\htdocs\featureserver\FeatureServer\DataSource\OGR.p
y", line 2, in ?
import ogr, osr
File "C:\Python24\Lib\site-packages\ogr.py", line 33, in ?
import _gdal
so it looks like ogr.py was found, but _gdal.pyd was not. They should
both be in site_packages.
Take a look at C:\Python24\Lib\site-packages, and see what's there.
there should be something like:
ogr.py
ogr.pyc
osr.py
osr.pyc
_gdal.pyd
gdal.py
gdal.pyc
gdalconst.py
gdalconst.pyc
gdalnumeric.py
gdalnumeric.pyc
in other words, _gdal.pyd should be in the same place as ogr.py, and
therefor importable.
By the way in future next releases this should be a bit cleaned up --
with eveything in site_packages/osgeo/
Hopefully these problems will be easier to solve then.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
