[Gdal-dev] about projection
chenxuexia xuex_chen at 126.com
Wed Oct 10 23:03:05 EDT 2007
 Hi all,when debug  gdalwarp.c, it runs to function GDALCreateGenImgProjTransformer( hSrcDS, pszSrcWKT, NULL, pszDstWKT, FALSE, 0, 1 ), the following error breaks out: ERROR1: No PROJ.4 translation for source SRS, coordinate transformation initialization has failed. then, i use depends-walker to view the gdalwarp.exe , one dependant dll  msjava.dll doesn't exist,  then i download it from a website. Another dependant dll mpr.dll is exceptional.  ÓÉÓÚÔÚÑÓʱ¼ÓÔØÒÀÀµÄ£¿éÖжªÊ§µ¼È뺯Êý£¬ÖÁÉÙÓÐÒ»¸öÄ£¿é¾ßÓв»ÄܽâÎöµÄµ¼Èë¡£(Funtion WNetRestoreConnectionA can't analtically import. )I'm afraid the version of my mpr.dll is wrong. If you run warp well, please give me an advice. Thank you.                                                           Xuexia Chen,                                                           BJ,China
//////////////////////////////////////////////////////////////////To a world, you're little, but to a person, you're the world. //////////////////////////////////////////////////////////////////
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071011/1fa698a5/attachment.html
