[Gdal-dev] How to Create a Geometry Filter
Roger André
randre at gmail.com
Thu Oct 11 12:08:40 EDT 2007
Sorry if I'm stepping on Frank here, but I'm scratching my head about
this. Probably means that I missed the point entirely. Seems like
the key question is, "select only features in an area bounded by 4
points." In Python, I do this like so:
#! /usr/bin/python2.4
'''Pulls all of the zipcode polys within a bounding box and returns
the Zip Code name and centroid coords. Spatial filtering needs min_
x, min_ y, max_x, max_y values'''
import ogr
drv = ogr.GetDriverByName( 'ESRI Shapefile' )
ds = drv.Open('zt06_d00.shp')
layer = ds.GetLayer(0)
filter_layer = layer.SetSpatialFilterRect(-122.166734286713,37.89091665754511,-122.3113385951359,37.79866675446653)
feature = layer.GetNextFeature()
name_field = feature.GetFieldIndex( 'NAME' )
while feature is not None:
name = feature.GetField( name_field )
print name
polygon = feature.GetGeometryRef()
centroid = polygon.Centroid()
print centroid
Easy, simple, and works well for me.
On 10/10/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Kent Eschenberg wrote:
> > Greetings,
> > This is a combination complaint/question. I'm trying to use the layer
> > classes' geometry filter to select only features in an area bounded by
> > 4 points.
> > I can't do that directly but must use SetSpatialFilter and first create
> > an instance of OGRPolygon. I do so and look for a way to set the
> > polygon's points.
> > I can't do that directly but must use addRing and first create an
> > instance of OGRLinearRing. I do that and look for a way to set the
> > ring's points.
> > I can't do that directly but must use importFromWkb and first create a
> > buffer of "the well known binary data".
> Kent,
> The convenience function SetSpatialFilterRect() shows the simpliest
> approach (in C++) to create a filter polygon with four points.
> void OGRLayer::SetSpatialFilterRect( double dfMinX, double dfMinY,
> double dfMaxX, double dfMaxY )
> OGRLinearRing oRing;
> OGRPolygon oPoly;
> oRing.addPoint( dfMinX, dfMinY );
> oRing.addPoint( dfMinX, dfMaxY );
> oRing.addPoint( dfMaxX, dfMaxY );
> oRing.addPoint( dfMaxX, dfMinY );
> oPoly.addRing( &oRing );
> SetSpatialFilter( &oPoly );
> In short, it is not normal practice to create WKB in programs, since
> that is ... not very convenient. It is a useful interchange format
> with other systems (ie. postgis).
> The OGRLinearRing isn't a "proper" OGC simple features geometry and
> so has no corresponding it WKB format. OGRLinearRings are only
> allowed to exist in the context of a polygon.
> I hope this helps.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
