[Gdal-dev] JP2MrSID driver. How to get it?
Daniele Romagnoli
dany.geotools at gmail.com
Mon Oct 15 16:00:40 EDT 2007
Hi list,
I have just a simple question for you.
I would like to test all the powerful drivers which are capable of handle
Jpeg2000 format.
I noticed that GDAL provides a wide set of JP2 drivers:
JP2KAK
JP2ECW
JP2MrSID
I already successfully tested the JP2KAK and the JP2ECW (by setting
GDAL_SKIP = JP2KAK) drivers.
Now I'm attempting to work with the JP2MrSID driver but I dont know how to
get it. I set GDAL_SKIP = JP2KAK JP2ECW (space separated list) but calling
"gdalinfo --formats" don't display JP2MrSID somewhere (only the simple
"MrSID" appears).
Do I need to properly configure NMAKE.opt in some manner? (I already enabled
MrSID support)
Or JP2MrSID is just a symbolic name to say that MrSID driver also allows
reading JP2 files? (Although JP2ECW and ECW appear separately)
Thank you very much for your help.
Best Regards,
Daniele Romagnoli
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071015/df0e5903/attachment.html
