[Gdal-dev] ng-python build
Christopher Barker
Chris.Barker at noaa.gov
Mon Oct 15 18:04:28 EDT 2007
William Kyngesburye wrote:
> by subdir of python specified in distutils, I mean whatever distutils
> uses by default but as a subdir of the gdal prefix. So for the OSX
> framework that ends up being:
> /Library/Frameworks/GDAL.framework/Versions/1.5/lib/python2.5/site-packages
I can't see that that should ever be the place to put python bindings.
> Actually, it's the --prefix that's putting it in the GDAL prefix.
hmm. My first thought is that the python bindings should ignore
"--prefix". I suppose, if anyone wanted it, you could have a
"--python-prefix", but I think that should really be a distutils option,
not one specific to gdal -- in short: python bindings should be
installed where python bindings belong.
> If
> you want distutils to put it in the default python site-packages (where
> the old bindings are installed, and where setuptools installs it), no
> prefix is needed.
right, but what if you want the gdal libs themselves somewhere other
than standard, but the python bindings installed properly in python.
> I was using a custom Xcode project, despite the framework option below I
> worked out. I'm hoping to use the framework option in the future (I
> should ;) when some kinks are worked out.
OK. I just ran configure with "--with-macosx-framework", but maybe I'll
wait to let you sort it out, because:
> Fixing that may require more fundamental changes in libtool
> configuration
I know NOTHING about libtool!
> (if even possible), but it would also simplify the
> framework build as a whole.
That would be nice, once it works.
Thanks for all your work on this,
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
