[Gdal-dev] gdal_merge and gdalwarp: Problems with 1 bit data
uwe.schmitz at lverma.nrw.de
Tue Oct 16 02:57:15 EDT 2007
gdal_merge and gdalwarp seem to have problems writing RasterBands
with 1 Bit depth. I'm using gdal-1.4.2 with old
python bindings(also tested with FWTools-1.3.7).
Let say I have a file called src.tif, where tiffinfo
shows:
TIFF Directory at offset 0x4bbd24
Subfile Type: (0 = 0x0)
Image Width: 6299 Image Length: 6299
Resolution: 400, 400 pixels/inch
Bits/Sample: 1
Compression Scheme: None
Photometric Interpretation: min-is-white
FillOrder: msb-to-lsb
Orientation: row 0 top, col 0 lhs
Samples/Pixel: 1
Rows/Strip: 6299
Min Sample Value: 0
Max Sample Value: 1
Planar Configuration: single image plane
and gdalinfo reports:
Driver: GTiff/GeoTIFF
Size is 6299, 6299
Coordinate System is:
PROJCS["DHDN / Gauss-Kruger zone 2",
Band 1 Block=6299x10 Type=Byte, ColorInterp=Palette
Metadata:
NBITS=1
Color Table (RGB with 2 entries)
0: 255,255,255,255
1: 0,0,0,255
Here I'm a little bit astonished to see Type=Byte
and ColorInterp=Palette, but may be it's caused by
abstraction of the interface.
Now if I do the following:
gdal_merge.py -co NBITS=1 -o dst.tif src.tif
the resulting file x.tif looks very jagged. Is this
a known problem?
I have to mention that gdal_translate doesn't have
this problem.
Greetings
Uwe
