[Gdal-dev] Parameter names in swig bindings
Ari Jolma ari.jolma at tkk.fi
Tue Oct 16 06:06:03 EDT 2007
I assume there's no problem in changing the parameter names in the
bindings? I'd like to rename the geom parameter to something else,
probably spatialFilter.
This because there's now a problem with the Perl typemap, which  says
that  geom must not  be null (as is the case where it is used elsewhere)
and in ExecuteSQL  geom is usually null.
Ari
Prof. Ari Jolma
Geoinformaatio- ja paikannustekniikka / Geoinformation and positioning
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
