[Gdal-dev] gdal_merge and gdalwarp: Problems with 1 bit data
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 16 14:55:50 EDT 2007
uwe.schmitz at lverma.nrw.de wrote:
> Hi,
> gdal_merge and gdalwarp seem to have problems writing RasterBands
> with 1 Bit depth. I'm using gdal-1.4.2 with old
> python bindings(also tested with FWTools-1.3.7).
Uwe,
I was not aware that GDAL 1.4.2 had any support for
writing 1bit files. FWTools does though.
> and gdalinfo reports:
> Driver: GTiff/GeoTIFF
> Size is 6299, 6299
> Coordinate System is:
> PROJCS["DHDN / Gauss-Kruger zone 2",
> Band 1 Block=6299x10 Type=Byte, ColorInterp=Palette
> Metadata:
> NBITS=1
> Color Table (RGB with 2 entries)
> 0: 255,255,255,255
> 1: 0,0,0,255
> Here I'm a little bit astonished to see Type=Byte
> and ColorInterp=Palette, but may be it's caused by
> abstraction of the interface.
One bit TIFF files have values 0 and 1. To get this
to display as black and white GDAL abstracts it to be
a paletted image. Note the GDAL data model does not
directly support 1bit data so we have to promote to byte.
> Now if I do the following:
> gdal_merge.py -co NBITS=1 -o dst.tif src.tif
> the resulting file x.tif looks very jagged. Is this
> a known problem?
I'm not sure what jagged means. I tried a quick
gdalwarp to 1 bit file using gdal trunk and it seemed
to work fine. I would suggest you file a detailed
bug report. You might even want to try first with
FWTools 1.3.9. There were some issues with FWTools
geotiff support for a couple revs recently due to the
bigtiff upgrade.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
