[Gdal-dev] Python next-gen bindings enabled in trunk
Christopher Barker
Chris.Barker at noaa.gov
Fri Oct 19 02:19:11 EDT 2007
William Kyngesburye wrote:
> Another issue to consider: where to install the python script programs.
> Currently they aren't installed at all.
Hmm. the usual place for python scripts installed with distutils in the
python scripts dir. On Linux, I think that's usually something like
/usr/local/bin. With an OS-X Framework build, it's something like:
/Library/Frameworks/Python......2.5/bin
(or something like that, inside the framework anyway -- not on a Mac now)
However, it might be more appropriate to put it in the GDAL "prefix"
location, as, ideally, fact that the scripts are python is an
implementation detail.
It may not matter much, as either location should be on the users PATH.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
