[Gdal-dev] Python next-gen bindings enabled in trunk
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 19 10:05:22 EDT 2007
Christopher Barker wrote:
> William Kyngesburye wrote:
>> Another issue to consider: where to install the python script
>> programs. Currently they aren't installed at all.
> Hmm. the usual place for python scripts installed with distutils in the
> python scripts dir. On Linux, I think that's usually something like
> /usr/local/bin. With an OS-X Framework build, it's something like:
> /Library/Frameworks/Python......2.5/bin
> (or something like that, inside the framework anyway -- not on a Mac now)
> However, it might be more appropriate to put it in the GDAL "prefix"
> location, as, ideally, fact that the scripts are python is an
> implementation detail.
> It may not matter much, as either location should be on the users PATH.
Chris,
I agree. I think python scripts should be installed by the makefile,
not setup.py, and should end up whereever the other utility programs
are installed.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
