[Gdal-dev] Python next-gen bindings enabled in trunk
Wed Oct 24 12:53:05 EDT 2007
Mateusz Loskot wrote:
> Frank Warmerdam wrote:
>> Vincent Schut wrote:
>>> My preferences:
>>> make: runs setup.py build make install: - runs setup.py install for
>>> bindings - separately installs scripts in prefix, alongside the
>>> other gdal utilities.
>> Folks,
>> This also sounds good to me, though I'd be ok with installing by
>> default in the Python tree as long as there is an easy way (driven by
>>  configure) to place stuff elsewhere.  Something like we do now with
>> --with-pymod-dir.
> Folks,
> I concur Frank's suggestion.
> Personally, I prefer to not to mess standard prefix locations
> with any files during process of development (building, testing,
> fixing). Ideally, I'd like to be able to use python bindings *without*
> necessity of running any install steps, as it is possible with old-gen
> python, though AFAIK it's not easy or even feasible with the new bindings.
Mateusz,
I do this all the time with the new bindings!  It's just that the
PYTHONPATH item I insert is messy.
warmerda at amd64[1]% echo $PYTHONPATH
/home/warmerda/gdal/swig/python/build/lib.linux-x86_64-2.4:/home/warmerda/mapserver/mapscript/python/build/lib.linux-x86_64-2.4
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
