[Gdal-dev] Segmentation fault in gdal_rasterize
Mateusz Loskot
mateusz at loskot.net
Wed Oct 24 19:18:51 EDT 2007
Mateusz Loskot wrote:
> Jean-Claude Repetto wrote:
>> But all the polygons are filled. Is it possible to draw only the
>> contours of the polygons ?
> Nope.
> Quoting Frank's old post:
> http://lists.maptools.org/pipermail/gdal-dev/2006-June/009294.html
> "GDAL's rasterization capability is not sophisticated from a render
> styling point of view. Other tools may be more appropriate if you want
> to do anything more sophisitcated that rasterize the polygons in a
> single solid color."
I put this to the FAQ
http://trac.osgeo.org/gdal/wiki/FAQRaster
Cheers
Mateusz Loskot
http://mateusz.loskot.net
