[Gdal-dev] ogr2ogr PostgreSQL and INTERLIS issues
Andreas Neumann
a.neumann at carto.net
Thu Oct 25 10:03:40 EDT 2007
> I try to avoid documentation for the OGR (or GDAL) drivers which
> is very specific to the GDAL and OGR utilities since I want the
> docs to make sense in the context of other programs using the drivers.
> So I'm inclined not to add this in the drv_pg.html docs, though there
> might be some clarification on layer names being prefixed with schema
> names that would be appropriate.
ok, thanks.
>> Question: can I use more than one layer in this case? Can I pass a
>> comma,separated list of layernames, or multiple -nln parameters? My
>> first
>> tests seem to indicate, not, which is a bit unfortunate. But maybe I
>> overlooked something ...
> No, you will basically need to run the ogr2ogr command once for each
> layer you want to process. Sorry.
well, no problem. I will write a shell-script. I am glad the update works
now.
Andreas
Andreas Neumann
Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
Email: a.neumann at carto.net, Web:
* http://www.carto.net/ (Carto and SVG resources)
* http://www.carto.net/neumann/ (personal page)
* http://www.svgopen.org/ (SVG Open Conference)
* http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
