[Gdal-dev] Should These Maps Be Aligned?
Dean Mikkelsen
dcmikkelsen at shaw.ca
Fri Oct 26 20:22:20 EDT 2007
I am not sure either, but another package I often use is uDig.
See: http://udig.refractions.net
Cheers,
Dean
----- Original Message -----
Date: Friday, October 26, 2007 5:17 pm
Subject: Re: [Gdal-dev] Should These Maps Be Aligned?
To: eschenbe at psc.edu
Cc: GDAL <gdal-dev at lists.maptools.org>
> Kent Eschenberg wrote:
> > I converted the relief map from its Lambert projection to geographic
> > (i.e., longitude and latitude) with gdalwarp. As far as I can
> tell the
> > roads already use that projection. No prj file came with the
> roads but
> > the included text file has this section:
> > Spatial_Reference_Information:
> > Horizontal_Coordinate_System_Definition:
> > Geographic:
> > Latitude_Resolution: 0.000278
> > Longitude_Resolution: 0.000278
> Geographic_Coordinate_Units: Decimal degrees
> > Geodetic_Model:
> > Horizontal_Datum_Name:
> North American Datum of 1983
> > Ellipsoid_Name: GRS1980
> > Semi-major_Axis: 6378137
> Denominator_of_Flattening_Ratio: 298.257222
> > I wrote a C++ program that with the gdal/ogr library reads
> these then
> > writes them in the VTK XML format.
> Kent,
> I don't know what's the VTK XML format, but AFAIK it's not
> supported by OGR.
> > These can then be used by a
> > scientific visualization program (ParaView) where we are also
> displaying> earthquake simulation results. I could have made an
> error, of course.
> > Is there some non-commercial software I could run on Linux to
> display> the road and relief maps together to check whether they
> are aligned?
> What about Quantum GIS, http://www.qgis.ogr
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Dean C. Mikkelsen, B.Sc., P.Eng.
Terra ETL Ltd.
Victoria, B.C., Canada
Phone: +1 (250) 88TERRA (83772)
http://www.terraetl.com
Consulting in Geodesy & GIS for the Natural Resources
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071026/3b81aae3/attachment.html
