[Gdal-dev] [Patch] Problem with gdal_translate with the parameter
-a_ullr 0 0 x x
Jean-Claude Repetto
jean-claude.repetto at worldonline.fr
Mon Oct 29 07:29:54 EDT 2007
Frank Warmerdam a écrit :
> Mateusz Loskot wrote:
>> Jean-Claude Repetto wrote:
>>> Jean-Claude Repetto wrote :
>>>> The ECW file is correct. I have checked it by reading it directly with
>>>> the ECW library.
>>>> The bug occurs when GDAL reads the file. I have looked at the source
>>>> code (version 1.4.2), and it seems the bug is in the file
>>>> ecwdataset.cpp .
>>> This is a patch that I propose :
>>> --- frmts/ecw/ecwdataset.cpp.orig 2007-10-24 11:35:44.000000000
>>> +0200
>>> +++ frmts/ecw/ecwdataset.cpp 2007-10-24 11:41:59.000000000 +0200
>>> @@ -1539,9 +1539,9 @@
>>> if( psFileInfo->fOriginX != 0.0
>>> || psFileInfo->fOriginY != 0.0
>>> - && (psFileInfo->fCellIncrementX != 0.0 &&
>>> + || (psFileInfo->fCellIncrementX != 0.0 &&
>>> psFileInfo->fCellIncrementX != 1.0)
>>> - && (psFileInfo->fCellIncrementY != 0.0 &&
>>> + || (psFileInfo->fCellIncrementY != 0.0 &&
>>> psFileInfo->fCellIncrementY != 1.0) )
>>> bGeoTransformValid = TRUE;
>>> With this patch applied to GDAL 1.4.2, both gdalinfo and qgis give
>>> correct results.
>> Jean-Claude,
>> Please, submit this patch as a ticket. We will test it. Thanks!
> Jean-Claude / Mateusz,
> This patch looks reasonable to me, and once the ticket is filed should
> likely be applied in 1.4 as well as trunk.
> Best regards,
I have filled a ticket for this bug (#1935), but it seems that the patch
has not been applied to 1.4.3 . Does it need more investigation ?
Regards,
Jean-Claude
