[Gdal-dev] 1.4.3 build and NG bindings
Brian Hamlin
maplabs at light42.com
Mon Oct 29 17:24:50 EDT 2007
On Oct 29, 2007, at 12:51 PM, Christopher Barker wrote:
> Brian Hamlin wrote:
>> If you have /usr/local/bin _before_ /usr/bin in your path, the python
>> install should work without help
> not quite. You need whatever place the python binaries are in your
> path. By default the framework builds installer adds the right path to
> your .profile (or whatever). For example, on my system:
> cbarker$ which python
> /Library/Frameworks/Python.framework/Versions/Current/bin/python
> and that is on my PATH.
:-) well, this is apparently not 100% settled out there
I used the Mac specific installer for python 2.5.1, and I didn't get
anything like that
I have a /usr/bin and /usr/local/bin which end up calling either
/System/Library or /Library/Frameworks pythons
typing `which python` results in the unix-style, not Mac specific,
paths on my OS X 10.10
I use `which python` to unravel this regularly
`env` clearly shows the PATH contents, on any of my several active
logins
I was sincerely hoping to stay out of this.. *sigh*
I trust that Chris and William and Howard will get this worked out
I thought that my post would be simple enough to be helpful to the
casual user, as I aspired to be
best
-Brian
> As William said, there is a "Unix tools" or something option that will
> put in sym links in /usr/local/bin for you too.
> Key is that what you get when you type "python" on the command line
> should be what the GDAL build system finds.
> -Chris
> Christopher Barker, Ph.D.
> Oceanographer
> Emergency Response Division
> NOAA/NOS/OR&R (206) 526-6959 voice
> 7600 Sand Point Way NE (206) 526-6329 fax
> Seattle, WA 98115 (206) 526-6317 main reception
> Chris.Barker at noaa.gov
