[Gdal-dev] 1.4.3 build and NG bindings
Christopher Barker
Chris.Barker at noaa.gov
Mon Oct 29 16:51:35 EDT 2007
Brian Hamlin wrote:
> If you have /usr/local/bin _before_ /usr/bin in your path, the python
> install should work without help
not quite. You need whatever place the python binaries are in your path.
By default the framework builds installer adds the right path to your
.profile (or whatever). For example, on my system:
cbarker$ which python
/Library/Frameworks/Python.framework/Versions/Current/bin/python
and that is on my PATH.
As William said, there is a "Unix tools" or something option that will
put in sym links in /usr/local/bin for you too.
Key is that what you get when you type "python" on the command line
should be what the GDAL build system finds.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
