[Gdal-dev] Building with Xerces 2.7.0, 2.8.0 and 3.0.0
Christian Schaffer christian.schaffer at muenchen.de
Thu Sep 6 06:27:40 EDT 2007
Hi Mateusz,
hi list,
building with Xerces 2.8.0 on Solaris 10 (x86) worked as described:
87 roses [gdal/ogr] # ogrinfo --formats
Supported Formats:
  -> "ESRI Shapefile" (read/write)
  -> "MapInfo File" (read/write)
  -> "UK .NTF" (readonly)
  -> "SDTS" (readonly)
  -> "TIGER" (read/write)
  -> "S57" (read/write)
  -> "DGN" (read/write)
  -> "VRT" (readonly)
  -> "AVCBin" (readonly)
  -> "REC" (readonly)
  -> "Memory" (read/write)
  -> "BNA" (read/write)
  -> "CSV" (read/write)
  -> "GML" (read/write)
  -> "KML" (read/write)
  -> "Interlis 1" (read/write)
  -> "Interlis 2" (read/write)
  -> "GMT" (read/write)
  -> "PostgreSQL" (read/write)
  -> "OCI" (read/write)
Thank you very much for your efforts.
Best regards,
Chris
Mateusz Loskot schrieb:
> Mateusz Loskot wrote:
>> After some tests, I confirm these problems, so I reported a ticket:
>> http://trac.osgeo.org/gdal/ticket/1799
>> I'm fixing it now and testing GDAL with Xerces 2.7.0, 2.8.0 and
>> 3.0.0.
> I applied some fixes to the OGR Interlis driver (SVN).
> I successfully tested current GDAL SVN with all three versions of
> Xerces. So, the ticket #1799 has been closed as fixed.
> Edward, Christian,
> I'd appreciate if you could try to build GDAL from SVN and see if it
> builds for you with Xerces support. If you will use GDAL sources tree
> that has been used before, please don't forget to clean it first, plus
> run autoconf, so configure is re-generated (soon, new regenerated
> version will go to SVN too, but for now you need to run autoconf):
> Here are recommended commands:
> $ cd /path/to/gdal/svn/trunk
> $ autoconf
> $ ./configure  \
> --with-xerces=yes \
> --with-xerces-inc=/usr/local/xerces-${XERCES_VERSION}/include \
> --with-xerces-lib="-L/usr/local/xerces-${XERCES_VERSION}/lib -lxerces-c
> -lpthread"
> $ make clean
> $ make
> Does it work now?
> Cheers
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070906/3c3d3cf3/attachment.html
