[Gdal-dev] OGR OLEDB Provider
John Cole john.cole at uai.com
Wed Sep 12 09:32:38 EDT 2007
-1
As someone who is using an OGR VRT->ODBC->SQL Server and not knowing an
OLEDB driver existed, I'd like to explore this thing and see if the
performance is better than my current solution (which when compared to
PostGIS, is sub-optimal but ok when compared to SDE).  Is there any
documentation available for this?
Also, I'm looking forward to the release of SQL Server 2008 with its spatial
extensions, and I would think that having an OLEDB driver would help speed
GDAL/OGR support for this backend.
Thanks,
John
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank Warmerdam
Sent: Tuesday, September 11, 2007 8:21 PM
To: gdal-dev
Subject: [Gdal-dev] OGR OLEDB Provider
Folks,
I am trying to go through the issues identified in the GDAL PROVENANCE.TXT
for the OSGeo Incubation with the aim of resolving them all for the GDAL/OGR
1.5.0 release.  Those that I can't resolve directly as I go, I am filing in
Trac with a "License" category.  One sticky one is some code in the OLE DB
provider.
While the problems might be resolvable by getting clear release statements
from the owners of the code from which parts were derived, I think it could
be tricky.  Also, the OLE DB provider isn't really a core component of
GDAL/OGR (just a layered add on) and it isn't widely used.  So I'm proposing
to just move it out of the GDAL trunk, perhaps into the "/spike" area of
subversion.
I've documented this issue in:
   http://trac.osgeo.org/gdal/ticket/1817
This email is soliciting feedback on the issue - primarily to see if there
are any objections to my taking this step.
The OLE DB provider would continue to be available, but it would not be
part of the standard GDAL distribution.  It would also likely get less
love and attention than it does now (which isn't really very much).
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.485 / Virus Database: 269.13.14/999 - Release Date: 9/10/2007
5:43 PM
No virus found in this outgoing message.
5:43 PM
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
