[Gdal-dev] Status Report KML Driver
Jens Oberender j.obi at troja.net
Wed Sep 12 11:11:15 EDT 2007
Hi Christopher
> is this project still in progress and whats the actual status?
> I'm curious to see the development since the 20th August 2007 because
> otherwise I'll need to implement KML support myself.
Mateusz added the KML read part to SVN.
Changes from last report:
- exporting LineString and Polygon works now
- exporting more tags as fields - description also exported
- get the layer extend works now
Not yet implemented:
- export with filters
- special case handling (GeometryCollections)
My next task are the GeometryCollections.
Please have a look at svn and give it a try.
Bye
	Jens
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070912/8c67e1e3/attachment.bin
