[Gdal-dev] problem compiling png in daily build
Sophia Parafina sophia.parafina at ionicenterprise.com
Thu Sep 13 08:08:25 EDT 2007
Frank,
That was it.  Thanks.
sophia
Frank Warmerdam wrote:
> Sophia Parafina wrote:
>> I tried to get around the problem by adding -DPNG_NO_ASSEMBER_CODE to
>> the CPPFLAGS in the png make file, but I get this error:
> Sophia,
> Perhaps you didn't do a clean build after that change?  That change
> seems to work for me.  Based on research by Even I have modified
> pngconf.h to disable assembly code on non-i386 systems so hopefully
> the next nightly snapshot will not have this issue.
>> /home/sparafina/gdal-scripts/unix/build/gdal-svn-trunk-2007.09.12/libgdal.so:
>> undefined reference to `DGN2IEEEDouble(void*)'
>> undefined reference to `AVCBinReadClose'
>> undefined reference to `AVCBinReadOpen'
>> undefined reference to `AVCBinReadNextTableRec'
> The above are related to --without-ogr I believe.  This configuration
> option seems to be broken just now, but there is a ticket filed on the
> issue.
> Best regards,
