[Gdal-dev] Problems with warping
Fri Sep 14 14:28:27 EDT 2007
Hugo Martins wrote:
> Hi gdal folks,
> Well i have been experiencing some problems with gdalwarp. I downloaded
> some imagery in jpg format. After i converted it to tif and no problem
> happened. These images are in Lisboa Hayford Gauss IgeoE projection and
> i need to reproject them to WGS84. Here are the gdalinfo from both files:
> As you see, there is some shift with the WGS84 projection.
> Could somebody help me on this?
Hugo,
I'm not clear on what exact problem you are seeing.  The lat/long bounds
of the original file and the gdalwarp file will be somewhat different since
the output file has been reprojected.  Generally speaking I would expect the
output file to represent a slightly larger area and if you look at the image
that there would be black triangles at the corners as a result of the
rotational effect of reprojection.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
