[Gdal-dev] Problems with warping
Joaquim Luis
jluis at ualg.pt
Mon Sep 17 18:00:41 EDT 2007
Hugo Martins wrote:
> Well i have been experiencing some problems with gdalwarp. I
> downloaded some imagery in jpg format. After i converted it to tif and
> no problem happened. These images are in Lisboa Hayford Gauss IgeoE
> projection and i need to reproject them to WGS84. Here are the
> gdalinfo from both files:
Hugo,
You didn't say how the reprojection to WGS84 was done but you need to
take into account the datum change.
Here is a proj4 string that permits to recover exactly the same results
as provided by the IgeoE coordinate conversions page.
+proj=tmerc +lat_0=39.66666666666666 +lon_0=-8.131906111111111 +k=1.0
+x_0=200000 +y_0=300000 +ellps=intl
+towgs84=-302.581,-61.360,103.047,0,0,0,0
Joaquim Luis
