[Gdal-dev] Trying the python bindings in windows
Christopher Barker
Chris.Barker at noaa.gov
Mon Sep 17 12:04:21 EDT 2007
Ari Jolma wrote:
> Thanks, then I just copied the files from build\lib.win32-2.5 to
> c:\python25\lib\site-packages and it seems to work.
The "proper" way to do that is:
python setup.py install
In this case, it may amount to the same thing, but for some packages,
the install process can involve a bit more (if nothing else, it usually,
pre-compiles all the python code).
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
