[Gdal-dev] Fwd: plate carree to latlon projection problem
Tue Sep 18 09:14:34 EDT 2007
jjknoops at netscape.net wrote:
> Hi Sjur,
> Thanks for your replay. I think you are right when saying it's caused by
> ellipsoid. So I have used this command to reproject
> /call gdalwarp -s_srs "+proj=eqc +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0
> +ellps=sphere +a=6378137.0 +es=0.0 +units=m" -t_srs "epsg:4326"
> /After comparing this result with previous results then I would say it's
> worse. The offset between the result from gdalwarp and erdas has
> increased. My college has also compared the results with envi and found
> that it's comparable to the erdas results.
Jaap,
Try:
    +a=6378137.0 +b=6378137.0 +units=m +towgs84=0,0,0" \
    -t_srs "+a=6378137.0 +b=6378137.0 +towgs84=0,0,0" ...
This attempts to do a warp from a projection on a spherical ellipsoid
to geographic coordinates on the same ellipsoid.
Note, using +a and +ellps will conflict and isn't a good idea.  And +es
is not recognised by GDAL's proj.4 parser which is not a complete proj.4
parser.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
