[Gdal-dev] Fwd: plate carree to latlon  projection problem
    jjknoops at netscape.net
    Tue Sep 18 09:55:13 EDT 2007
 Hi Frank and Sjur,
My problem is solved. The method from frank made a good reprojection. It's even better then the erdas reprojection.
The method was:
gdalwarp -s_srs "+proj=eqc +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378137.0 +b=6378137.0 +units=m +towgs84=0,0,0"? -t_srs "+proj=longlat +a=6378137.0 +b=6378137.0 +towgs84=0,0,0"
 The only strange thing is that this means data projection parameter provided by data supplier is not correct.
Thank you both for helping me.
Best regards,
Jaap Knoops
-----Original Message-----
To: jjknoops at netscape.net
Cc: gdal-dev at lists.maptools.org
Sent: Tue, 18 Sep 2007 3:14 pm
Subject: Re: [Gdal-dev] Fwd: plate carree to latlon  projection problem
jjknoops at netscape.net wrote:?
> Hi Sjur,?
> Thanks for your replay. I think you are right when saying it's caused by
> ellipsoid. So I have used this command to reproject?
> /call gdalwarp -s_srs "+proj=eqc +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0
> +ellps=sphere +a=6378137.0 +es=0.0 +units=m" -t_srs "epsg:4326"?
> /After comparing this result with previous results then I would say it's
> worse. The offset between the result from gdalwarp and erdas has
> increased. My college has also compared the results with envi and found
> that it's comparable to the erdas results.?
Jaap,?
Try:?
gdalwarp -s_srs "+proj=eqc +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0?
?  +a=6378137.0 +b=6378137.0 +units=m +towgs84=0,0,0" \?
?  -t_srs "+a=6378137.0 +b=6378137.0 +towgs84=0,0,0" ...?
This attempts to do a warp from a projection on a spherical ellipsoid?
to geographic coordinates on the same ellipsoid.?
Note, using +a and +ellps will conflict and isn't a good idea.  And +es?
is not recognised by GDAL's proj.4 parser which is not a complete proj.4?
parser.?
Best regards,?
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com?
light and sound - activate the windows | http://pobox.com/~warmerdam?
and watch the world go round - Rush    | President OSGeo, http://osgeo.org?
________________________________________________________________________
Check Out the new free AIM(R) Mail -- Unlimited storage and industry-leading spam and email virus protection.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070918/71debf3d/attachment.html
