[Gdal-dev] Cs2cs input from file in Windows
Thu Sep 20 12:42:42 EDT 2007
Jukka Rahkonen wrote:
> Hi,
> I am sure that this must be trivial, but I just don't manage to take input for
> cs2cs utility.  I have read the document and understood that I should just write
> the input file name(s) last in the command line. However, when I do this cs2cs
> is still waiting for standard input.  Using '<file' did not help either. I am
> running cs2cs from FWTool 1.3.6 on Windows.
Jukka,
I tried:
C:\warmerda>more < input.txt
-10 33
C:\warmerda>cs2cs +proj=utm +zone=11 +datum=WGS84 < input.txt
121d29'19.801"W 0d0'1.072"N 0.000
C:\warmerda>
This is with FWTools 1.3.7 for windows.  How did you results
differ?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
