[Gdal-dev] History of Java support...
Tamas Szekeres szekerest at gmail.com
Mon Sep 24 19:39:04 EDT 2007
Hi Rick,
There have been a couple of the folks supporting the java bindings in
the past but none of them could continue this effort due to the lack
of their time. So you are welcomed if you can provide a kinda
permanent support for this binding. I'm not aware of any serious
issues from the java side right now.
Best regards,
Tamas
2007/9/24, Rick Brownrigg <brownrigg at sunflower.com>:
> Hi,
> I'm curious as to the state of the Java bindings support for GDAL.  It
> looks like as of 1.4.2, it is considered unsupported.  I'm looking for
> insights as to why:  is it as simple as "no one has stepped up to the
> plate", or more complex like "folks have found the performance under
> java to be too slow/unstable/..."?   I'm very interested in using the
> GDAL API with Java, and would consider supporting it if its simply a
> matter of a volunteer.  But I'd certainly like to hear about why Java is
> not more actively promoted presently.
> Thanks,
> Rick Brownrigg
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
