[gdal-dev] how to use ogr to change the postgis file to shape file
Mateusz Loskot
mateusz at loskot.net
Sat Apr 19 04:59:31 EDT 2008
windwxc at sina.com wrote:
> So someone tell me i can
> use ogr to transform the data from postgis to shape by code but now i
> cannot find a good example how to it .
Have you read the OGR Tutorial?
http://gdal.org/ogr/ogr_apitut.html
Also, you should complete it with reading the docs about Shapefile
and PostgreSQL providers:
http://gdal.org/ogr/drv_shapefile.html
http://gdal.org/ogr/drv_pg.html
Next, check the CSharp Wiki:
http://trac.osgeo.org/gdal/wiki/GdalOgrInCsharp
where you will find links to C# apps examples at
http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps
Now, combine the exmaple of OGR reading/writing presented in the OGR
Tutorial
with CSharp interface, leveraging information about how to connect to
Shapefile/PostgreSQL
datasets to in read and write modes.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
