[gdal-dev] question about ogr
Mateusz Loskot
mateusz at loskot.net
Sat Apr 19 10:51:24 EDT 2008
windwxc at sina.com wrote:
> hi,everyone. i meet a question about org. i use VisualStudio2005 with windows XP and i have copy some ogr dll file to bin of my application project.but when i run my project and throw a error, it fails at the first line: Ogr.RegisterAll(). Error is "The type initializer for 'OSGeo.OGR.Ogr' threw an exception." I find someone meet same question but his method cannot well run and i still cannot find the reason. The following is my codes and i add "using OSGeo.OGR;".
> public void GetGeometry(string sqltext)
> try
> Ogr.RegisterAll();
> catch (Exception e)
> { MessageBox.Show("regesiter failor:" + e.Message); }
> //OSGeo.OGR.Geometry myGeom;
> try
> OSGeo.OGR.DataSource conn = Ogr.Open("PG:host=locatal dbname=stdb user=stuser password=123", 1);
> OSGeo.OGR.Layer myLay = conn.ExecuteSQL(sqltext, null, "tt");
> conn.Dispose();
> catch (Exception e)
> { MessageBox.Show("open file failor:" + e.Message);
> please help me.
> thank you!
> windsnow
If you don't mind, I'd have two requests:
1. Please, use meaningful subject. It will help people to read your posts
as well as search through the archives.
2. Please DO NOT send your posts in HTML (http://asciiribbon.org/). As
you can see above, your post is completely unreadable as messed with
XML/HTML entities.
Thank you!
Greetings
Mateusz Loskot
http://mateusz.loskot.net
