[gdal-dev] MapServer's image quality stinks serving up these NOAA
NRCs
Christopher Barker
Chris.Barker at noaa.gov
Mon Apr 21 12:40:01 EDT 2008
Vincent Schut wrote:
> but my first guess
> would be: don't use palette images, use rgb or rgba.
Yes, I think this is the issue too. If you re-scale or warp or
interpolate palleted images, GDAL uses nearest neighbor interpolation,
which gets pretty ugly with images like the RNCs.
> You can control
> this with a mapserver output file format parameter,
I don't know what your rendering stack looks like, but it may not be
that simple. What you need to do is make sure that the RNCs are
converted to RBG BEFORE they are altered in any other way -- then all
warping, re-scaling, etc can be done with a better interpolation scheme.
I suspect you'll need to convert them, store them on disk that way, so
that what MapServer is seeing is the RGB versions.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
