[gdal-dev] Metadata supported by NITF Driver
Visser, John B. JohnB.Visser at ga-asi.com
Tue Apr 22 14:39:22 EDT 2008
Experimenting with GDALINFO, I've discovered that I can extract the
annotations through the "CGM" domain and the TREs through the "TRE"
domain.  Are there other metadata domains supported by the NITF driver?
Is there some way to explore the available domains?  (If not, that would
be a useful feature, I think.)
Finally, I notice the NITF file header is broken up into name/value
pairs, but is there some way to access it directly in its non-broken up
state?
Thanks,
John Visser
