[gdal-dev] MapServer's image quality stinks serving up these NOAA
NRCs
Christopher Barker
Chris.Barker at noaa.gov
Thu Apr 24 12:24:06 EDT 2008
Vincent Schut wrote:
> Those kap files are single-band colortable images, right?
yes.
> I'd use
> nearest neighbour interpolation than, for gdalwarp, instead of bilinear.
> Simple removing the '-rb' switch from your gdalwarp command should do
> the trick, as nn is the default.
Will GDAL even try to do bilinear with colortable images? I think it may
only do NN anyway.
Which is why I suggested that converting to RBG should be the first
step, before any warping or rescaling.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
