[gdal-dev] RE: ogr2ogr PostgreSQL to shp
Randy George
rkgeorge at cadmaps.com
Sat Apr 26 10:54:22 EDT 2008
I'm attempting to extract a subset of a PostGIS table to shp using this
windows command line:
"C:\Program Files\FWTools2.1.0\bin\ogr2ogr" --debug on -where " fips =
'08041' " -f "ESRI Shapefile" out.shp PG:"user=user dbname=db host=localhost
password=pass port=5432" gnis
Here is the debug output:
OGR_PG: DBName="db"
OGR_PG: PostSIS version string: '1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1' ->
'1.3'
OGR_PG: POSTGIS_VERSION=1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
ERROR 1: PG:user=user dbname=db host=localhost password=pass port=54
32 is neither a file or directory, Geoconcept access failed.
FAILURE:
Unable to open datasource `PG:user=user dbname=db host=localhost
password=pass port=5432' with the following drivers.
Where am I going wrong?
thanks
randy
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080426/271b9075/attachment.html
