[gdal-dev] RE: ogr2ogr PostgreSQL to shp
Frank Warmerdam
warmerdam at pobox.com
Sat Apr 26 12:14:59 EDT 2008
Randy George wrote:
> Hi,
> I’m attempting to extract a subset of a PostGIS table to shp using this
> windows command line:
> "C:\Program Files\FWTools2.1.0\bin\ogr2ogr" --debug on -where " fips =
> '08041' " -f "ESRI Shapefile" out.shp PG:"user=user dbname=db
> host=localhost password=pass port=5432" gnis
> Here is the debug output:
> OGR_PG: DBName="db"
> OGR_PG: PostSIS version string: '1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1'
> -> '1.3'
> OGR_PG: POSTGIS_VERSION=1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> ERROR 1: PG:user=user dbname=db host=localhost password=pass port=54
Randy,
Does ogrinfo on this postgres database work? The fact that you got the
postgis version info back indicates that the database was successfully
connected to.
Skimming the Postgres driver code, I suspect it failed to identify any
layers in your postgres database. This can happen if you have a
geometry_columns table but no entries in it. I'm not sure why else it
might happen.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
