[gdal-dev] netcdf option build error
Jeshua Lacock
jeshua at OpenOSX.com
Tue Apr 29 11:04:27 EDT 2008
On Apr 29, 2008, at 8:45 AM, William Kyngesburye wrote:
> Are you using an SDK? Even though Xcode 3.0 now adds a symlink to /
> usr/local/lib in the SDKs, it doesn't add /usr/local/include, which
> can cause random include errors (especially not saying a header file
> is missing, but giving errors as if it was missing). If you have
> netcdf installed in some other location, you need to add a symlink
> to it in the SDK.
I am using Xcode 3 and just building for the native platform, and I am
not building to /usr/local, everything is built in /Library/OpenOSX/
grass.
> If not using and SDK, dunno. Works for me.
> What about HDF4? If you are compiling GDAL with that as well, make
> sure to use the --disable-netcdf option in HDF4.
Yes, I am compiling GDAL with HDF4 and hdf5 as well, so I will look at
disabling it in HDF - although I did not enable it in HDF4 or hdf5
(maybe it was enabled by default).
Based on Frank's response, HDF seems to be the culprit.
I will post when I have a better idea what's going on.
Thanks,
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 877.240.1364
