[gdal-dev] netcdf option build error
William Kyngesburye
woklist at kyngchaos.com
Tue Apr 29 15:23:03 EDT 2008
I looked thru my notes on HDF4 to see if there was anything else. Are
you compiling on Intel OSX? There is a small endian issue in HDF4 for
Intel OSX where it will define the constants as bigendian, but only
for 32bit OSX. In hconv.h, line 66, none of the tested machine values
match OSX Intel (__i386 or __i386__), so OSX Intel gets caught as
bigendian.
I don't know if this is enough to affect the definition of
MAX_VAR_DIMS or not. I do see that MAX_VAR_DIMS is a backward-
compatibility define for Netcdf v2 - netcdf.h lines 912+. The modern
version is NC_MAX_VAR_DIMS. Did you use --disable-v2 when configuring
netcdf?
On Apr 29, 2008, at 1:19 PM, Jeshua Lacock wrote:
> On Apr 29, 2008, at 12:00 PM, William Kyngesburye wrote:
>> The current HDF4.2r2 has that --disable-netcdf configure flag I
>> mentioned, there is no need for the -DHAVE_NETCDF mentioned on the
>> wiki, and I don't know if the current HDF4 works with that old
>> manual method. Or the -fPIC (default on OSX already) or -lm (will
>> be found in the automatically linked libSystem).
> Thats what I figured, but I tried them both anyways. I would hate to
> ignore advice...
> Buggers! I guess I am stumped without really hacking things up...
> Thanks,
> Jeshua Lacock, Owner
> <http://OpenOSX.com>
> phone: 877.240.1364
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
