[gdal-dev] netcdf option build error
Jeshua Lacock
jeshua at OpenOSX.com
Tue Apr 29 15:36:01 EDT 2008
On Apr 29, 2008, at 1:23 PM, William Kyngesburye wrote:
> I looked thru my notes on HDF4 to see if there was anything else.
> Are you compiling on Intel OSX? There is a small endian issue in
> HDF4 for Intel OSX where it will define the constants as bigendian,
> but only for 32bit OSX. In hconv.h, line 66, none of the tested
> machine values match OSX Intel (__i386 or __i386__), so OSX Intel
> gets caught as bigendian.
Yes; I am currently doing our Intel build.
> I don't know if this is enough to affect the definition of
> MAX_VAR_DIMS or not. I do see that MAX_VAR_DIMS is a backward-
> compatibility define for Netcdf v2 - netcdf.h lines 912+. The
> modern version is NC_MAX_VAR_DIMS. Did you use --disable-v2 when
> configuring netcdf?
No I did not try disable-v2, do you think I should?
Thanks for your help - if you are interested, I would be happy to pay
you to SSH in and take a look...
Best,
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 877.240.1364
