[gdal-dev] netcdf option build error
William Kyngesburye
woklist at kyngchaos.com
Tue Apr 29 16:39:14 EDT 2008
On Apr 29, 2008, at 2:36 PM, Jeshua Lacock wrote:
> On Apr 29, 2008, at 1:23 PM, William Kyngesburye wrote:
>> I looked thru my notes on HDF4 to see if there was anything else.
>> Are you compiling on Intel OSX? There is a small endian issue in
>> HDF4 for Intel OSX where it will define the constants as bigendian,
>> but only for 32bit OSX. In hconv.h, line 66, none of the tested
>> machine values match OSX Intel (__i386 or __i386__), so OSX Intel
>> gets caught as bigendian.
> Yes; I am currently doing our Intel build.
You should probably add __i386__ to the define tests here.
>> I don't know if this is enough to affect the definition of
>> MAX_VAR_DIMS or not. I do see that MAX_VAR_DIMS is a backward-
>> compatibility define for Netcdf v2 - netcdf.h lines 912+. The
>> modern version is NC_MAX_VAR_DIMS. Did you use --disable-v2 when
>> configuring netcdf?
> No I did not try disable-v2, do you think I should?
No - the GDAL HDF4 driver is expecting the v2 name.
> Thanks for your help - if you are interested, I would be happy to
> pay you to SSH in and take a look...
It's a hobby for me. And all I can offer is what I've found that
works for me, I don't know if poking around in your setup will help.
Note: I've been *slowly* updating my build instructions on my site,
but I haven't gotten to the GIS stuff yet. Here's a quick-n-dirty
summary of the relevant bits to your problem (assuming everything
needed in /usr/local, otherwise a lot of --with options needed):
- netcdf
./configure --disable-f77 --disable-cxx --disable-examples --disable-
dependency-tracking --disable-utilities
- HDF4 4.2r2
hconv.h: apply the endian patch
./configure --disable-fortran --disable-dependency-tracking --disable-
netcdf
- GDAL (fill in other options you need):
./configure --with-threads --without-grass --with-netcdf=/usr/local --
with-hdf4=/usr/local
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
